Asus GeForce GTX 950 Strix 2GB Overclocking Results
With the power limit set to 111 percent and the temperature limit at 95°C, we set about ramping up the clocks. We managed to add a full 100MHz to the base clock, giving us a new speed of 1,265MHz (1,455MHz boost). This is a 9 percent overclock compared to Asus's factory settings, or 24 percent over reference. At this speed, the card boosted consistently to above 1.5GHz, topping out at around 1.55GHz – an excellent result.
The memory was stable up to an astounding 8.2GHz effective, a massive 24 percent increase over stock speeds. This is clearly a great result but it does reinforce our belief that the GTX 950 Strix should come with a memory overclock applied out of the box.
        Sapphire Radeon R9 380 Nitro 4GB
        Palit GeForce GTX 960 Super JetStream 2GB
        Asus GeForce GTX 950 Strix 2GB (OC)
        Gigabyte GeForce GTX 950 OC 2GB
        Sapphire Radeon R7 370 Nitro 4GB
          20
          30
          40
          50
          60
          70
          80
          90
    Frames Per Second
        Sapphire Radeon R9 390X Tri-X 8GB
        Sapphire Radeon R9 390 Nitro 8GB
        AMD Radeon R9 290X 4GB
        Gigabyte GeForce GTX 950 OC 2GB (OC)
          20
          30
          40
          50
          60
          70
          80
    Frames Per Second
          1000
          1500
          2000
          2500
    Score (higher is better)
